ONTAP Hardware
lrep_writer very slow
BRN_IT_SUPPORT
Hello
I am trying to baseline a snapvault Relationship between a FAS2040 (8.1.2.7-mode) and a FAS2240 (8.2.1.7-mode).
At the source I successfully used lrep_reader and dumped data to an USB disk.
At the destination, I use lrep_writer from a Windows server on the SAN. While everything seems correct, snapvault status show a very slow progression (<2Mb/s).
I double checked all network setting and verified that my server can upload data to the file at more than 20MB/sec. I also verified that there is no bandwidth limitation on the snapvault Relationship.
Any idea of what could limit my transfer rate ?
thank you all
best regards,
1 REPLY 1
nicholaf
Is SnapVault compression on or off?
To check enter the command 'options snapvault.ossv.compression'
Regards,
Nicholas Lee Fagan
