ONTAP Hardware
netapp ds2246 used
chima
I want to buy a used netapp ds2246. but the seller has 4 units but does not have the connection cables, I want to know what I need to be able to test if it works...?
To use them in windows do I need some licensed software...?
do you recommend using it on windows or is it better to use it on linux...?
1 ACCEPTED SOLUTION
AlexDawson
NetApp DS2246 disk shelves are manufactured and certified for use with NetApp ONTAP systems. Any off-label use is not something we can assist with. You would be better to view https://reddit.com/r/homelab for that sort of question.
Thanks!
2 REPLIES 2
AlexDawson
Thanks!
chima
This solución no work for My. Thanks.
