ONTAP Hardware
network adapter in a 2552
James_Pohl
What is the model and manufacturer of the internal network adapters.
We are having some difficulty connecting our management ports to a Cisco Nexxus and Cisco Fex. The Netapp will connect on one side of our redundedant switches but not the other.
We'd like to know what the manufacturer of the network adapter chipset.
If there is a command to show the PCI output it would be appreciated.
The best we can get so far is
c1n1*> version
NetApp Release 8.3P2:
c1n1*> sysconfig -v
slot 0: Quad Gigabit Ethernet Controller 82580
e0a MAC Address: 00:a0:98:7c:a4:50 (auto-1000t-fd-up)
e0b MAC Address: 00:a0:98:7c:a4:51 (auto-unknown-down)
e0M MAC Address: 00:a0:98:7c:a4:52 (auto-1000t-fd-up)
e0P MAC Address: 00:a0:98:7c:a4:53 (auto-1000t-fd-up)
Device Type: 150E
Firmware Version: 3.22, 0x80000101
which I am guessing is a 82580 Intel chipset but I'd like to offer more than a guess.
Thanks for your help
1 REPLY 1
Sahana
Yes, it is 82580 Intel chipset.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
