ONTAP Hardware
sysconfig -r
jackaguilar
Hi please help me interpret these data. Thanks.
RAID Disk Device HA SHELF BAY CHAN Pool Type RPM Used (MB/blks) Phys (MB/blks)
dparity 2a.01.12 2a 1 12 SA:A - SAS 15000 560000/1146880000 560208/11473076
88
parity 2a.01.11 2a 1 11 SA:A - SAS 15000 560000/1146880000 560208/11473076
88
1 ACCEPTED SOLUTION
rwelshman
The HA stands for Host Adapter.
The "88" is just wrap around from the line above, it is part of the disk size.
4 REPLIES 4
rwelshman
Could you be more specific? What are you trying to figure out? Those are two 600 GB 15K SAS disks - both parity, on shelf 1 attached to adapter 2a, bay 12 and 11.
jackaguilar
What does 88 means and the column HA? Thanks!
rwelshman
jackaguilar
Thanks!
