ONTAP Hardware
unable to delete a LUN
dirkdigs
ONTAP API Failed: Unable to check if Config Replication is enabled. Wait a few seconds, and then try the command again. (Error: 13001)
Array is FAS2552
7 REPLIES 7
Ontapforrum
I haven't dealt/seen this error before, but I am guessing it is trying to check the replication status due to mention of 'config-replication', is there SVM-DR in place ? Have you checked the config replication is ok?
At the admin privilege level.
::*> snapmirror config-replication status show
::*> snapmirror config-replication status show-communication
Have you tried deleting it from the CLI?
dirkdigs
those commands dont work
Ontapforrum
Go to advance priv level:
::>set adv
try again.
dirkdigs
procedures.
netapp_p::> set adv
Warning: These advanced commands are potentially dangerous; use them only when
         directed to do so by NetApp personnel.
Do you want to continue? {y|n}: y
netapp_p::*> snapmirror config-replication status show
Error: "config-replication" is not a recognized command
netapp_p::*> snapmirror config-replication status show-communication
netapp_p::*>
Ontapforrum
what ontap version are you running ? Also, if you just enter 'snapmirror' and do tab support, what options do you see...?
Just press tab after snapmirror, do you see option 'config-replication' ?
::*> snapmirror
dirkdigs
 ok that's interesting the commands only work on one of the nodes.
Ontapforrum
What do you mean by only work on one of the nodes?
could you tell me - If this is a one-2-one relationship between LUN and Volume ? Or, there are more LUns in that volume.  if there is just one lun (that you intend to delete) in that volume and there is no relationships (dr protection), then simply take the volume offline and delete it, it will remove the space held by the lun.
