Tech ONTAP Blogs
Manila: How to get it running in DevStack with Juno
DeepakRaj
NetApp
"This article was orignally published on Aug 15, 2014"
In our previous blog (Overview of Manila at Atlanta OpenStack Summit), we spoke about the Atlanta summit and the new OpenStack File Share Service project called Manila. This is a follow up with some information that will assist you getting Manila installed within a DevStack environment. We will show you some of the steps and links that are available that will provide information about the installation, and get you started with Manila – think of this as a Manila 101 🙂
Important Note: This blog is for the stable/Juno branch of Manila with Devstack.
The test infrastructure being used is a VM with the following details:
  • Ubuntu 14.04 LTS as the OS
  • Three interfaces:
    • Management Interface
    • Interface used for the Bridge Network
    • Interface for my Storage Network
  • Devstack (the master branch)
  • Manila (the master branch) from Stackforge
Important Point about the Host OS version
  • Ubuntu 14.04 was required due to blueprints that provided upstream changes in Neutron that required a minimum version of dnsmasq to be 2.63. Ubuntu 12.04 (Precise) has version 2.59.
Now, let’s walk thru the steps to get devstack and Manila setup on your host (almost all of the steps will be via the command line, with one confirmation of viewing shares via Horizon):
  1. Clone the master branch of devstack:
    <span class="w">stack@greg:~$ </span><span class="nc">git</span><span class="kv"> clone -b master https://github.com/openstack-dev/devstack.git
    </span>Cloning into 'devstack'...
    remote: Counting objects: 19577, done.
    remote: Compressing objects: 100% (29/29), done.
    remote: Total 19577 (delta 11), reused 3 (delta 0)
    Receiving objects: 100% (19577/19577), 5.51 MiB | 663.00 KiB/s, done.
    Resolving deltas: 100% (13436/13436), done.
    Checking connectivity... done.​
  2. Clone the master branch of Manila from GitHub using the stable/juno branch:
    <span class="w">stack@greg:~/devstack$ </span><span class="nc">git</span><span class="kv"> clone -b stable/juno https://github.com/openstack/manila.git
    </span>Cloning into 'manila'...
    remote: Counting objects: 5538, done.
    remote: Compressing objects: 100% (47/47), done.
    remote: Total 5538 (delta 39), reused 15 (delta 10)
    Receiving objects: 100% (5538/5538), 2.64 MiB | 0 bytes/s, done.
    Resolving deltas: 100% (3633/3633), done.
  3. Copy Manila-specific files into the devstack environment:
    <span class="w">stack@greg:~$ </span><span class="nc">cp</span><span class="kv"> ./manila/contrib/devstack/lib/manila ./devstack/lib
    </span><span class="w">stack@greg:~$ </span><span class="nc">cp</span><span class="kv"> ./manila/contrib/devstack/extras.d/70-manila.sh ./devstack/extras.d/</span>​
  4. Create your local.conf file with the appropriate values. More importantly, there are specific things for Manila required prior to running of stack.sh . Below is a sample local.conf with the items required for Neutron and Manila denoted with the comment #MANILA-SPECIFIC-STUFF-BELOW .
    <span class="c"># Credentials</span>
    <span class="nv">DATABASE_PASSWORD</span><span class="o">=</span>devstack
    <span class="nv">ADMIN_PASSWORD</span><span class="o">=</span>devstack
    <span class="nv">SERVICE_PASSWORD</span><span class="o">=</span>devstack
    <span class="nv">SERVICE_TOKEN</span><span class="o">=</span>devstack
    <span class="nv">RABBIT_PASSWORD</span><span class="o">=</span>devstack
    <span class="nv">GUEST_PASSWORD</span><span class="o">=</span>devstack
    <span class="nv">MYSQL_HOST</span><span class="o">=</span>127.0.0.1
    <span class="nv">MYSQL_USER</span><span class="o">=</span>root
    <span class="nv">MYSQL_PASSWORD</span><span class="o">=</span>devstack
    <span class="nv">RABBIT_HOST</span><span class="o">=</span>127.0.0.1
    <span class="nv">LIBVIRT_TYPE</span><span class="o">=</span>qemu
    <span class="nv">GLANCE_HOSTPORT</span><span class="o">=</span>127.0.0.1:9292
    <span class="nv">ENABLED_SERVICES</span><span class="o">=</span>key,n-api,n-crt,n-obj,n-cpu,n-net,n-cond,n-sch,n-novnc,n-xvnc,n-cauth
    <span class="c">#glance</span>
    ENABLED_SERVICES+<span class="o">=</span>,g-api,g-reg
    <span class="c">#cinder</span>
    ENABLED_SERVICES+<span class="o">=</span>,cinder,c-sch,c-api,c-vol,c-bak
    <span class="c">#trove</span>
    ENABLED_SERVICES+<span class="o">=</span>,trove,tr-api,tr-tmgr,tr-cond
    <span class="c">#manila</span>
    ENABLED_SERVICES+<span class="o">=</span>,manila,m-api,m-sch,m-shr
    <span class="c">#others</span>
    ENABLED_SERVICES+<span class="o">=</span>,horizon,rabbit,mysql,tempest
    <span class="c">#neutron needs for manila</span>
    disable_service n-net
    enable_service q-svc,q-agt,q-dhcp,q-l3,q-meta,neutron
    <span class="c">#</span>
    <span class="nv">LOGDAYS</span><span class="o">=</span>1
    <span class="nv">LOGFILE</span><span class="o">=</span><span class="nv">$DEST</span>/devstack.log
    <span class="nv">SCREEN_LOGDIR</span><span class="o">=</span><span class="nv">$DEST</span>/logs/screen
    <span class="nv">RECLONE</span><span class="o">=</span>yes
    <span class="nv">API_RATE_LIMIT</span><span class="o">=</span>False
    <span class="c">#MANILA-SPECIFIC-STUFF-BELOW</span>
    <span class="nv">HORIZON_REPO</span><span class="o">=</span>https://github.com/NetApp/horizon.git
    <span class="nv">HORIZON_BRANCH</span><span class="o">=</span>manila_juno
    <span class="nv">Q_PLUGIN</span><span class="o">=</span>ml2
    <span class="nv">ENABLE_TENANT_VLANS</span><span class="o">=</span>True
    <span class="nv">ML2_VLAN_RANGES</span><span class="o">=</span>physnet1:100:4000
    <span class="nv">PHYSICAL_NETWORK</span><span class="o">=</span>physnet1
    <span class="nv">OVS_PHYSICAL_BRIDGE</span><span class="o">=</span>br-eth1
    <span class="nv">Q_ML2_PLUGIN_MECHANISM_DRIVERS</span><span class="o">=</span>openvswitch
    <span class="nv">Q_ML2_PLUGIN_TYPE_DRIVERS</span><span class="o">=</span>vlan,vxlan
    <span class="nv">SHARE_BACKING_FILE_SIZE</span><span class="o">=</span>8G
    <span class="nv">FLAT_INTERFACE</span><span class="o">=</span>eth1
    Important Note for local.conf and Manila:
    - Your network configuration may be different than our example. Configure Neutron according to your network and VLAN ranges
    - Ensure that you add vxlan to the Q_ML2_PLUGIN_TYPE_DRIVERS parameter. This was a change to upstream Icehouse.
    - Note the changes for version of Horizon for the integration with Manila and Shares
  5. Let’s make sure we have the necessary dependencies
    sudo apt-get update &amp;&amp; \
    sudo apt-get -y install git vim-gtk libxml2-dev libxslt1-dev libpq-dev python-pip libsqlite3-dev &amp;&amp; \
    sudo apt-get -y build-dep python-mysqldb &amp;&amp; sudo pip install git-review tox
  6. Run stack.sh as you normally would after you have configured the local.conf for the manila components as well as any items specific for your environment.
  7. Once stack.sh has completed, you should have the Manila service(s) running with a default install. Use the manila service-list command to ensure you are running.
    <span class="w">stack@greg:~/devstack$ </span><span class="nc">manila</span><span class="kv"> service-list
    </span>+------------------+---------------+------+---------+-------+----------------------------+
    |      Binary      |      Host     | Zone |  Status | State |         Updated_at         |
    | manila-scheduler |      greg     | nova | enabled |   up  | 2014-08-08T17:48:32.000000 |
    |   manila-share   | greg@backend1 | nova | enabled |   up  | 2014-08-08T17:48:40.000000 |
  8. Check Horizon to validate the Manila plugins are available. We don’t have any shares defined yet; but we need to confirm that the Manila plugins for Horizon are available.
  9. List your Neutron networks and subnets available for your devstack installation. Take a note of each listed prior to creating your Manila share:
    <span class="w">stack@greg:~$ </span><span class="nc">neutron</span><span class="kv"> net-list
    </span>+--------------------------------------+------------------------+----------------------------------------------------+
    | id                                   | name                   | subnets                                            |
    | 003cdc18-cd83-4d8c-880d-73abef80ca4c | public                 | 9f0ff94d-0c17-4e68-88c4-92da33df8448 172.24.4.0/24 |
    | 83b9d824-1186-4aed-82df-da84adca39b1 | private                | 5d70ffc6-e26a-4189-a522-7fb9b1c2eb23 10.0.0.0/24   |
    | e18fa903-183b-4de6-b4ad-a08e52faa9c8 | manila_service_network |                                                    |
    <span class="w">stack@greg:~$ </span><span class="nc">neutron</span><span class="kv"> subnet-list
    </span>+--------------------------------------+----------------+---------------+------------------------------------------------+
    | id                                   | name           | cidr          | allocation_pools                               |
    | 5d70ffc6-e26a-4189-a522-7fb9b1c2eb23 | private-subnet | 10.0.0.0/24   | {"start": "10.0.0.2", "end": "10.0.0.254"}     |
    | 9f0ff94d-0c17-4e68-88c4-92da33df8448 | public-subnet  | 172.24.4.0/24 | {"start": "172.24.4.2", "end": "172.24.4.254"} |
  10. Create a share network using the Neutron private network and subnet for your environment. We used the generic private network/subnet for this example.
    <span class="w">stack@greg:~/devstack$ </span><span class="nc">manila</span><span class="kv"> share-network-create --neutron-net-id 83b9d824-1186-4aed-82df-da84adca39b1 --neutron-subnet-id 5d70ffc6-e26a-4189-a522-7fb9b1c2eb23 --name manila_share
    </span>+-------------------+--------------------------------------+
    |      Property     |                Value                 |
    |        cidr       |                 None                 |
    |     created_at    |      2014-08-11T19:30:34.698596      |
    |    description    |                 None                 |
    |         id        | 438032da-1147-4cc4-864a-cf691953def9 |
    |     ip_version    |                 None                 |
    |        name       |             manila_share             |
    |    network_type   |                 None                 |
    |   neutron_net_id  | 83b9d824-1186-4aed-82df-da84adca39b1 |
    | neutron_subnet_id | 5d70ffc6-e26a-4189-a522-7fb9b1c2eb23 |
    |     project_id    |   ede0edb1c1e54e3eabc6e6c98b17d862   |
    |  segmentation_id  |                 None                 |
    |       status      |                 None                 |
    |     updated_at    |                 None                 |
    <span class="w">stack@greg:~/devstack$ </span><span class="nc">manila</span><span class="kv"> share-network-list
    </span>+--------------------------------------+---------------+--------+
    |                  id                  |      name     | status |
    | 438032da-1147-4cc4-864a-cf691953def9 |  manila_share |  None  |
    | b098a3cd-3b4b-4d7e-b51d-a7476dc761cc | manila_share1 |  None  |
  11. Create an NFS share, using the share network that you just created. Here we are creating the share “devstack_share�? using the share network we created in the previous step.
    <span class="w">stack@greg:~/devstack$ </span><span class="nc">manila</span><span class="kv"> create --name devstack_share --share-network 438032da-1147-4cc4-864a-cf691953def9 NFS 1
    </span>+----------+---------------------------------------------------------------------------------------------------------------------------+
    | Property |     Value        |
    |    id    | e9b92837-ea2b-4acd-ab65-65c98199e78b        |
    |  links   | [{u'href': u'http://10.63.168.135:8786/v1/ede0edb1c1e54e3eabc6e6c98b17d862/shares/e9b92837-ea2b-4acd-ab65-65c98199e78b',  |
    |          |   u'rel': u'self'},        |
    |          |  {u'href': u'http://10.63.168.135:8786/ede0edb1c1e54e3eabc6e6c98b17d862/shares/e9b92837-ea2b-4acd-ab65-65c98199e78b',     |
    |          |   u'rel': u'bookmark'}]        |
    |   name   | devstack_share        |
    <span class="w">stack@greg:~/devstack$ </span><span class="nc">manila</span><span class="kv"> list
    </span>+--------------------------------------+----------------+------+-------------+-----------+---------------------------------------------------------------+
    |                  ID                  |      Name      | Size | Share Proto |   Status  |                        Export location                        |
    | 4ed16b64-59ee-4123-b6f0-f42148280a99 |    myshare     |  1   |     NFS     | available | 10.254.0.3:/shares/share-4ed16b64-59ee-4123-b6f0-f42148280a99 |
    | e9b92837-ea2b-4acd-ab65-65c98199e78b | devstack_share |  1   |     NFS     |  creating |                              None                             |
  12. Now that this share that has been created, let’s take a quick look at the shares. We have two shares, myshare and devstack_share. Each uses the NFS protocol and the export paths for each share are listed in the ‘export location’ column.
    | e9b92837-ea2b-4acd-ab65-65c98199e78b | devstack_share |  1   |     NFS     | available | 10.254.0.5:/shares/share-e9b92837-ea2b-4acd-ab65-65c98199e78b |
  13. The export location is part of the Manila shared server configuration. There are two shared servers in this example because we created two different shares on two different share networks. Take a moment within your environment to follow the relationships between your share and share network.
  14. Earlier we asked that you check out the lists of Neutron subnets. You should now have an additional entry that will route the subnet used for the NFS exports to your private subnet used to build the share network via Manila.
    <span class="w">stack@greg:~/devstack$ </span><span class="nc">neutron</span><span class="kv"> subnet-list
    </span>+--------------------------------------+------------------------------------------------+---------------+------------------------------------------------+
    | 0d75e8af-ea21-4668-b0c1-351937bee35a | routed_to_5d70ffc6-e26a-4189-a522-7fb9b1c2eb23 | 10.254.0.0/28 | {"start": "10.254.0.2", "end": "10.254.0.14"}  |
  15. Let’s quickly check on the share and find where the backing Cinder volume was created. In my environment, I’m using a NetApp Cinder back end in this example. The backing Cinder volume for my Manila shares can be seen via a df –hk on the single-node devstack host.
    <span class="w">stack@greg:~/devstack$ </span><span class="nc">df</span><span class="kv"> -kh
    </span>Filesystem                                    Size  Used Avail Use% Mounted on
    /dev/sda1                                      34G  5.7G   26G  18% /
    none                                          4.0K     0  4.0K   0% /sys/fs/cgroup
    udev                                          7.9G  4.0K  7.9G   1% /dev
    tmpfs                                         1.6G  840K  1.6G   1% /run
    none                                          5.0M     0  5.0M   0% /run/lock
    none                                          7.9G  4.0K  7.9G   1% /run/shm
    none                                          100M     0  100M   0% /run/user
    172.16.22.230:/v_devstack_mirror               15G   50M   15G   1% /opt/stack/data/nova/mnt/3edfeba0731309866b6773b9828448eb
    172.16.22.230:/v_devstack_comp                9.5G  9.5M  9.5G   1% /opt/stack/data/nova/mnt/57975883130c2c9c4aab078fe8f72404
  16. Now you’ve created a Manila NFS share! But what next? We need to allow access to this share for some hosts. In this example, I will provide access to the share devstack_share to two different hosts in my test environment. From here – we would mount the NFS shares on the NFS client specific by the IP address of the access-allow command.
    <span class="w">stack@greg:~/devstack$ </span><span class="nc">manila</span><span class="kv"> access-list e9b92837-ea2b-4acd-ab65-65c98199e78b
    </span>+----+-------------+-----------+-------+
    | id | access type | access to | state |
    <span class="w">stack@greg:~/devstack$ </span><span class="nc">manila</span><span class="kv"> access-allow e9b92837-ea2b-4acd-ab65-65c98199e78b ip 10.63.168.135
    </span>+-------------+--------------------------------------+
    |   Property  |                Value                 |
    |  access_to  |            10.63.168.135             |
    | access_type |                  ip                  |
    |  created_at |      2014-08-12T12:44:28.112086      |
    |   deleted   |                False                 |
    |  deleted_at |                 None                 |
    |      id     | 104a8ce8-bb2e-47a7-84a0-06e7b7dc148a |
    |   share_id  | e9b92837-ea2b-4acd-ab65-65c98199e78b |
    |    state    |                 new                  |
    |  updated_at |                 None                 |
    <span class="w">stack@greg:~/devstack$ </span><span class="nc">manila</span><span class="kv"> access-allow e9b92837-ea2b-4acd-ab65-65c98199e78b ip 10.0.0.6
    |   Property  |                Value                 |
    |  access_to  |               10.0.0.6               |
    | access_type |                  ip                  |
    |  created_at |      2014-08-12T12:44:36.326327      |
    |   deleted   |                False                 |
    |  deleted_at |                 None                 |
    |      id     | ec398f37-cbf4-4cd2-bc28-7a92fcbe0167 |
    |    state    |                 new                  |
    |  updated_at |                 None                 |
    </span>+--------------------------------------+-------------+---------------+--------+
    | 104a8ce8-bb2e-47a7-84a0-06e7b7dc148a |      ip     | 10.63.168.135 | active |
    | ec398f37-cbf4-4cd2-bc28-7a92fcbe0167 |      ip     |    10.0.0.6   | active |
That’s all for now; we will follow up with more on Manila in later blog posts, including a discussion of the integration with the NetApp clustered Data ONTAP driver for Manila. To learn more about Manila, check out our wiki page at http://wiki.openstack.org/wiki/Manila.
NetApp is committed to fostering open source solutions. You can learn more about our contributions by joining our Discord channel
