Tech ONTAP Blogs
Two Ways Customers Are Using StorageGRID for Analytics and Data Protection
aronk
NetApp
Introduction
Modern data platforms rarely serve a single purpose.
The same object store that feeds analytics and AI pipelines is often expected to support other applications including long-term retention, backup, and recovery.
Across industries, we are seeing two leading StorageGRID usage patterns emerge:
  1. Analytics and AI platforms querying data directly from object storage
  1. Data protection platforms using object storage as a scalable, policy driven target
While these workloads are different, successful organizations design for both from the start.
Path 1: Analytics and AI on Object Storage
Analytics teams increasingly expect:
  • SQL access to large object datasets
  • Open table formats and catalogs
  • Fast onboarding without data movement
In this model, StorageGRID acts as the system of record for raw and curated datasets. Analytics engines register tables directly against object data, enabling multiple teams to query the same datasets without creating copies.
For data engineers, this reduces pipeline complexity.
For data platform leaders, it supports modernization without locking into a single engine or vendor.
The key architectural shift is treating object storage not as cold storage, but as a foundational platform for analytics
Path 2: Data Protection at Scale
At the same time, infrastructure teams face growing pressure to:
  • Retain more data for longer periods
  • Improve recovery confidence
  • Control costs as capacity scales
In this pattern, StorageGRID provides a highly durable, policy driven object platform that integrates cleanly with enterprise backup and recovery tools. Infrastructure teams retain ownership of lifecycle, protection, and capacity planning, while downstream tools consume storage transparently.
This allows organizations to consolidate data protection infrastructure without sacrificing visibility or governance.
Why These Paths Converge on StorageGRID
What makes these two paths compatible is not the workloads, it’s the architecture.
StorageGRID is designed to:
  • Scale capacity independently of compute
  • Apply consistent lifecycle and protection policies
  • Support multiple consumers without interference
For infrastructure leaders, this means a single object platform that doesn’t fragment over time.
For analytics leaders, it means reliable access to governed data without waiting on storage redesigns.
Designing for Both from Day One
Organizations that succeed with both analytics and data protection avoid treating these as separate storage problems.
Instead, they design StorageGRID as a shared foundation:
  • Infrastructure teams manage durability, lifecycle, and footprint
  • Data teams focus on performance, schemas, and analytics value
  • Builders onboard quickly
Closing
Whether your priority is analytics modernization or scalable data protection, StorageGRID is increasingly used as the common layer that enables both.
Explore the StorageGRID solution page to see how these solutions come together.
To illustrate how we support the different paths discussed above, we’re sharing new resources that showcase real-world examples and provide practical guidance:
