Tech ONTAP Articles
The Industry’s First All-Flash Array with 15 TB SSDs
Tech_OnTap
June 2016
Jim Lyons
Senior Technology Writer
NetApp
Until recently, very few companies needed to store over one petabyte (PB) of data. Today, it's commonplace. Similarly, the high cost and limited capacity of flash-based drives often meant that SSDs were only used for the most performance-sensitive applications. Today, the prospect of hosting the majority of your business applications on all-flash storage is no longer considered far-fetched.
NetApp® customers are leading this trend, with 70% of All Flash FAS (AFF) users already running mixed SAN and NAS workloads in VMware environments. Now, with the availability of 15 TB SSD drives and ONTAP® 9 software, more applications can benefit from the performance, reliability, and operational simplicity of flash than ever before.
Welcome to the One Petabyte (2U) Flash Expansion Shelf
The 15TB high-capacity SSDs will expand the use cases for all-flash storage systems to include:
  • Space constrained data centers. The combination of 15TB SSDs and storage efficiencies means that you only need 2U to store what would take up to 32U using 2TB SATA disks, and also results in significant power and cooling savings.
  • Applications that require both low latency and high capacity. For example, an application that mines massive genomic data repositories in order to tailor treatment plans for patients with life-threatening conditions, where every second counts.
  • Mixed SAN and NAS environments that can benefit from all-flash ease-of-management, with ONTAP QoS features used to deliver performance where it’s needed the most.
The table below lists the usable and effective capacities for common configuration options.
Storage Shelves Storage Configuration Usable Capacity * Total Effective Storage Capacity @ 4:1
1 12 x 15.3 TB SSDs 123 TB  492 TB
1 24 x 15.3 TB SSDs 289 TB 1,156 TB
2 36 x 15.3 TB SSDs 414 TB 1,656 TB
2 48 x 15.3 TB SSDs 580 TB 2,320 TB
*Based on root-data-data partitioning, RAID DP maximum group size of 23, and one spare partition per controller.
  • Usable capacity = the total storage available after accounting for RAID parity, spares, and reserves.
  • Total effective storage capacity = the amount of logical data that can be stored based on savings from storage efficiency technologies, including data compaction, compression, and deduplication.
Of course, other SSD drive capacities are also supported, including 400, 800, 1600 and 3800 GB varieties, and you can mix-and-match SSD capacities within aggregates, drive stacks, and clusters. NetApp storage experts can help you determine the best combination of performance and capacity for your own environment.
In case you’re wondering why the total effective storage capacity in the table shows a 4:1 ratio — it reflects our new effective capacity guarantee based on the savings expected from the default settings on an AFF system, which includes inline compaction, compression and deduplication. Because your mileage may vary, ONTAP 9 makes it easy to track your savings using the NetApp AutoSupport dashboard, which provides a view of the overall savings by cluster-node and identifies the contribution provided by different types of efficiency technologies.
Enterprise-Grade Data Management and Sub-millisecond Performance
The ability to lead the industry with 15TB SSD support is a testament to the software innovations available in ONTAP 9. Unlike companies that are developing proprietary hardware designs, NetApp uses off-the-shelf SSD drives and has enhanced the ONTAP operating system to deliver scalable sub-millisecond performance along with enterprise-grade data management features. For example, AFF systems running ONTAP 9 can deliver up to 60% more IOPS at less than 1ms latency, compared with ONTAP 8.3. Database benchmarking for AFF systems running ONTAP 9 provided the following results:
  • Oracle 12c OLTP testing with AFF 8008 EX
    • 309K IOPS at 1ms latency with Inline efficiencies enabled
    • 75% select, 25% update, 8KB I/O size
  • Microsoft SQL Server OLTP testing with AFF 8080 EX
    • 339K IOPS at 1ms latency
    • 90:10 read/write, 8KB average I/O size
The flexibility to mix-and match all-flash nodes with hybrid nodes in a scale-out cluster is yet another AFF advantage versus other all-flash solutions. Currently, 55% of AFF customers replicate their space-efficient flash snapshots to disk storage on a hybrid FAS system that is part of a common cluster.
Supported Configurations
Upon introduction, the new 15 TB SSDs are only supported on new AFF 8080 systems that run ONTAP 9 and which use our new 2U, DS224C 12gbps SAS disk shelves. Over time, support will be extended to additional platforms and configurations, including other AFF 8000 models, AFF MetroCluster, and FAS systems running ONTAP 9 software or later.
What’s Next?
Within the past year alone, SSD capacity points have increased over 10x, from 400GB to 4TB. Today, NetApp systems are available with 15TB SSDs that are 50% larger than the biggest hard disk drives, with effective capacities that further amplify the advantages of flash storage over disk. With 32TB SSD drives expected to arrive in 2017, and with flash component suppliers continuing to drive the price curve for SSDs lower, it’s only a matter of time until the all-flash data center becomes a reality.
Learn more about ONTAP 9 from Jay Subramanian, NetApp vice-president of ONTAP Product Management, by registering for this webcast on Tuesday June 21.
Please Note:
All content posted on the NetApp Community is publicly searchable and viewable. Participation in the NetApp Community is voluntary.
In accordance with our Code of Conduct and Community Terms of Use, DO NOT post or attach the following:
  • Software files (compressed or uncompressed)
  • Files that require an End User License Agreement (EULA)
  • Confidential information
  • Personal data you do not want publicly available
  • Another’s personally identifiable information (PII)
  • Copyrighted materials without the permission of the copyright owner
Continued non-compliance may result in NetApp Community account restrictions or termination.
