AFF
AFF200 9.3P4 Digital certificate for a SVM (Storage Virtual Machine) has expired
thomas382
Hello;
Our Autosupport alerts me that Digital certificate for a SVM (Storage Virtual Machine) has expired
The following certificates have expired: 054995932C8243, 054A0BCAD30B9B, 054A0C4B4848CB, ... and 1 other.
Potential Impact: Clients may not be able to connect to the cluster over secure (SSL based) protocols.
With  security certificate show i ge
Vserver    Serial Number   Common Name                            Type
cluster1   054995932C8243  cluster1                               server
    Certificate Authority: cluster1
          Expiration Date: Wed Feb 28 12:34:11 2018
svm_cifs   054A0BCAD30B9B  svm_cifs                               server
    Certificate Authority: svm_cifs
          Expiration Date: Tue Mar 06 09:36:31 2018
svm_iscsi  054A0C4B4848CB  svm_iscsi                              server
    Certificate Authority: svm_iscsi
          Expiration Date: Tue Mar 06 10:12:26 2018
svm_nfs    054A0BF82F3094  svm_nfs                                server
    Certificate Authority: svm_nfs
          Expiration Date: Tue Mar 06 09:49:12 2018
KB ID: 27617   Fits for cdot 8.2 + 8.3, we have cdot 9.3P4 and we need slightly diferent syntax, so I want to verify that:
1. Can i renew the expired Certs without any connectivity loss?
2. Is this Command Syntax for cdot 9.3P4 correct?
security certificate create -vserver cluster1 -common-name cluster1 -size 2048 -type server -country AT -expire-days 3650 -hash-function SHA256
Many Thanks, Thomas
1 REPLY 1
chenguanghui
hello:
Renewing the server certificate on the data SVM has no effect.
The following link is the command for CRL to renew a certificate.
    https://kb.netapp.com/on-prem/ontap/DM/Encryption/Encryption-KBs/How_to_renew_an_ONTAP_self-signed_SSL_certificate_via_command_line
i hope to help you
Best regards.
