AFF
Autogrow for NFS datastore volumes for Linux Machines
AdminNetapp091320
Hello Experts,
I have an activity to do and the current size of my NFS Datastore for Linux machines is 6TB. Linux folks requesting to make it 8TB because they will be doing multiple VM snapshots. Do I have to make it 8TB or should I trust the NFS auto grow up to 8TB configured in the volume for Linux.? I'm a bit confuse and not sure if VMWARE also sees auto grow on Netapp volume. Please advise, thanks in advance.
1 ACCEPTED SOLUTION
Ontapforrum
NFS auto-grow should work fine if auto-grow is enabled (with auto-grow max size defined appropriately) and the containing aggregate can supply more space on demand. However, if you are concerned and thinking about it, especially if there is sudden spike of usage, it is better to size it to 8TB, as you will be in more control with extra space already allocated.
2 REPLIES 2
Ontapforrum
EWILTS_SAS
I don't trust autogrow/autoshrink for anything except my snapvault destinations.  I always resize my volumes manually so I am in control.  This also makes it more predictable to the end user - they can see the final size right away.  Especially if you have thin-provisioning on, sizing to the max doesn't hurt anything (and for NFS, always use logical space reporting and enforcement, not physical).
