AFF
E2760 How do you get into the CLI serial port using putty.
Scott_G
Does anyone have the settings for putty for the serial connection and the key sequense to get into DIAGS to reinit the array?
1 ACCEPTED SOLUTION
Mulya
Hi @Scott_G ,
Assuming you are using putty in your laptop, please use the following
Connection type: Serial
Speed: 115200
Serial Line: your laptop COM port
Thank you,
Mulya
4 REPLIES 4
Mulya
Hi @Scott_G ,
Speed: 115200
Thank you,
Mulya
pedro_rocha
Do you have an active support contract with NetApp?
"SSH is not a supported management protocol for E-Series devices. To manage the storage array, there is SANtricity for GUI based management or SMcli for the command line.
For support procedures, occasional Telnet or SSH access is required. However, it is not possible to use Telnet/SSH for day-to-day operations."
Nevertheless, I would try: default all and 115200 or 9600
Scott_G
Thanks for the reply. Yes, 115200 is the baud rate. I was trying to get into the Service level CLI with is a key sequence when you login thru the serial port. I figured out.  Thxs!
ExactLabSysAdmin
Hi Scott_G,
I guess you used a mini-usb to rs232 cable. Can you share the cable part-number?
And how did you get into the Service level CLI?
Thanks.
