AFF
How to convert a FAS to AFF.
xGeox
Hello guys, I am looking for information and what are the bootloader arguments that are needed to convert to the FAS8000 platform to an AFF.
I am not able to find the information from the KB cause recently was migrated and all the information changed.
1 ACCEPTED SOLUTION
andris
@xGeox : Conversion is normally not permitted, unless there was a technical issue (or bug) that has changed the personality.  Open a technical support case to investigate the issue and come up with a mitigation.
5 REPLIES 5
SpindleNinja
There's very few platforms it (was) allowed for and I think it was for only one way too...   I do recall reading that that KB was moved to internal.   see: https://community.netapp.com/t5/FAS-and-V-Series-Storage-Systems-Discussions/Converting-AFF-A300-to-FAS8200/td-p/145607
Have you reached out to your account team to see if it's an option to convert? Also, why are you needing to do this?
Mjizzini
The environment variable bootarg.init.flash_optimized must be set to true on both nodes in an HA pair of All-Flash Optimized FAS80x0 systems.
How to check and configure the All Flash FAS (AFF) optimized personality on FAS80x0 controllers.
SpindleNinja
That appears to be an internal doc..
andris
Ontapforrum
Agree with andris here.
Also, It's not just about changing the 'bootarg.init.flash_optimized' option, the internal KB is available on the Internet (if you are ok to pay for it, strangely). Anyway, the point is not that. There is a whole 'commercial aspect to it' Licensing & Regulation which must be followed and it's up to NetApp.
Internal KB is available here:
https://www.scribd.com/document/375571405/How-to-Check-and-Configure-the-All-Flash-FAS-AFF-Optimized-Personality-on-FAS80x0-Controllers
