AFF
NetApp Direct Connectivity with HPE Synergy
AhmedAl-Batoosh
we need to Establishing direct connectivity between your NetApp storage system AFF-C800 and the HPE Synergy environment !! is possible ???
 CAN YOU, explain to me the steps also the if there are Teachnical PDF
Iraq
5 REPLIES 5
chamfer
Hi @AhmedAl-Batoosh ,
Can you advise:
  1. What protocol do you need (FC/Ethernet)?
  2. What modules are in the AFF-C800?
  3. What modules are in the HPE Synergy
Ethernet connectivity from a HPE Virtual Connect SE 100Gb F32 Module to AFF-C800 shouldn't be an issue.  Fibre Channel I wouldn't think would be supported for direct connect.
AhmedAl-Batoosh
hi chamfer
-NFS for VMware environment NFS over 40/100GbE)
-100GbE / 40GbE Ethernet ports (for data LIFs)
-ONTAP configured for SAN(NFS) /NAS (SMB) protocols
-Redundant controllers for HA available
-HPE Virtual Connect SE 40/10Gb
Iraq
chamfer
With NFS over 40Gb Ethernet there should be no issues direct connecting to the HPE VC SE 40/10Gb module.  These are essentially network switches, there are limitations with FC, but it should be no issues.
I would ensure that the AFF is connected via a full mesh where each controller has ports to each HPE VC module.
AhmedAl-Batoosh
THANK YOU FOR YOUR FEEDBACK
kindly, could you please provide document or link for technical
Iraq
chamfer
Sorry I am not sure that there is a document for this exact scenario.
