AFF
Proposal Help needed
Proposal_Help_Needed_NOW
Is there somewhere on the NOW Site I can plug in all requirements our customer has and then it will generate a proposal on what hardware/OS should be used?
My email is [email protected].  Please email me any info/links you may have that will help me with this task.
Here is a SMALL example on what we need....  Could of sworn there is a proposal generator online here, just cannot remember where it's located at... Need this today ASAP.
  • 2TB onboard cache memory on total
    • Expandable to 4TB
  • Storage system shall support a minimum of 14 PB in scale-out
  • 16 FC ports 8/16Gbps LC transceivers (including transceivers same speed)
    • FC wiring for same ports number up to 30 meters
  • 24 SSD with 960GB capacity
  • 72 HD with 1.8TB capacity; 10,000 rpm
  • 60 HD with 8TB capacity; 7,200 rpm
  • 12 HD with 900GB capacity; 10,000 rpm
  • The system shall have Support for disks type SAS, 10K RPM with 1.2TB capacity and 1.8TB, support SATA 4TB disks. NL-SAS 6, 8 and 10TB as well as SSD disks of at least 960GB up to 15TB
1 ACCEPTED SOLUTION
SpindleNinja
If you're a partner you can use Fusion.
3 REPLIES 3
SpindleNinja
Not sure I have access to fusion.  Do you have a link for it I can try it.. If not, I'm hoping for another way...
I do have acccess thankk you!
