AFF
Trouble finding Max Current of AFF-A150
NetApp93
Hello All,
I am filling out some change request documents for our new AFF-A150 install that we are doing later this month. Data center documentation is requesting the Max Current in ampere of the device, presumably for power allocation per rack. I have thus far been unable to identify this statistic - the only thing close that I could find was the "Power Consumption (Median)" which was 300W. I found some old data center documentation from previous tech refreshes, where my predecessor had put "6.3" for our most recent install of an AFF-A220 and "4.7" for a FAS2520. Searching for these numbers and these systems have also not yielded any results.
If anyone could point me in the right direction, I would appreciate it. Thank you in advance.
1 ACCEPTED SOLUTION
SpindleNinja
have you checked hwu.netapp.com?
2 REPLIES 2
SpindleNinja
NetApp93
Thanks for this! Was unaware of this site, found what I needed. Cheers
