AFF
how can select aggr for NAS & SAN  when use ADP
AhmedAl-Batoosh
Iraq
1 ACCEPTED SOLUTION
ChLokesh
Hello Ahmed,
We do not need to select aggr’s NAS and SAN work loads.
  • An aggregate is a collection of physical disks only.
  • We need to specify the raid type, the owner node and some disk related parameters while creating an aggr. NAS and SAN are not specified here.
https://docs.netapp.com/us-en/ontap-cli/storage-aggregate-create.html#parameters
  • Vols, Qtrees, LUNs are logical entities which get created on top of an aggr through which client can access data and these are dedicated to SVM's or Vservers.
  • We have to specify the NAS and SAN protocol (nfs|cifs|fcp|iscsi) at the vserver level. Not at the aggr level.
Hope this information is helpful.
3 REPLIES 3
cedric_renauld
Hello,
The AGGR is the support for Volimes, Volime can contain NAS or-and LUN
you chose the protocole in the SVM config, @this point you can select NAS or SAN SVM
the AGGR with or without ADP can manage the twice
AhmedAl-Batoosh
could you expalin more .
also if you have Documnet for that
Iraq
ChLokesh
Hello Ahmed,
