Command throwing exception, even if power-shell code is working fine
kailas
Facing issue with custome volume creation command i.e. command is throwing an exception , I checked the powershell code logs , code is executing successfully, after code execution command is throwing an exception , without any details.
2 REPLIES 2
raj_shrivastava11
Hi Kailas,
Could you please tell us which exact step it is failing. You can also try in logging each step via Get-WFALogger -Info -message to see where it is failing?
BR
Raj
kailas
I already tried putting checkpoints in script using Get-WFALogger -Info -message , powershell script is woring fine, till last line of code , after that the command is throwing anexception, if you see the screenshot last line is the msg , "Flexvol created successfully"
