System is using single path HA attached storage
dstrebel
New to Netapp and dont know what this error is "System is using single path HA attached storage" any thoughts?
3 REPLIES 3
danielpr
You need to check if the disk shelf are in multi path. Check the Cluster cable connectivity.
Thanks
Daniel
BrendonHiggins
A DS14mk2 or DS14mk4 have two of what is know as a electronically switched hub (ESH) module in them.  They are labled A and B.  Each esh has an in and an out port.  If you connect 1 filer to the A port and the other filer to the B port, both filers can see the disks and you have an active / active cluster.  So if a cable is pulled out or a HBA laser dies, the second filer can take over.
In a HA environment.  The 1st filer is conected to the A port in but also the B port out.  The is reversed on the 2nd node B in and A out.  This is HA in an active / active enviroment.
If you just have a single file put one cable to the A and the other to the B.
You can see if it is working
storage show disk -p
Have a look at page 16 & 17
http://media.netapp.com/documents/tr-3437.pdf
Hope this help
Brendon
BrendonHiggins
Better yet
http://now.netapp.com/NOW/knowledge/docs/hardware/filer/215-03304_A0.pdf
Multipath and Dual-Path Cabling Information
