Additional Virtualization Discussions
XenServer, FC protocol and SnapManager products
thome
I am designing an environment that will use XenServer for virtualization, and will virtualized Exchange 2003 and SQL 2005 servers.
Can I use the associated SnapManager products (SQL, Exchange, Oracle) with XenServer VMs using fibre channel as my protocol of choice on this Windows 2003 based VMs?
In a VMWare environment I would use Raw Device Mappings, but I can't figure out if something similar can be done in XenServer.
I have reviewed the best practice guide here:
http://media.netapp.com/documents/tr-3732.pdf
Thoughts?
Gerry
7 REPLIES 7
jherlihy1
Hi Gerry,
just wondering how you got on with this, as I've got a similar environment where XenServer 5.6 with FC LUNs will be used and they would also like to use SMSQL & SME for the MSSQL and Exchange VMs.
Did you need to directly map the LUNs via iSCSI to the VMs for Snapdrive/snapmanager to work, or were you able to get FC LUNs to work ok with Snapdrive on the VM through XenServer?
Cheers,
John
ralfaro01zero
Hi jherlihy-1
Citrix recommends as a best practice to use NFS for the VM repository, for SnapManager I would go with iSCSI (XS don't support raw device mapping), if you are concerned about performance i think the smart move is to use 10Gb ethernet.
Cheers.
jherlihy1
Thanks for that - that's the conclusion I came to as well although I couldn't find it documented that Citrix actually recommends that. Do you have a URL (off the top of your head:) that shows that?
I found some posts which stated that any XS VMs which had Snapdrive installed (for use with SnapManager etc) had trouble booting and running normal backups with VSS if their non-NetApp disks (ie C: drive) were not on NFS. Something to do with XS StorageLink creating a separate LUN for every disk on a VM (including the C: drive) and mapping through the physical device name (ie "NETAPP LUN") which was confusing Snapdrive when the VSS hardware provider was called.
Cheers,
John
ralfaro01zero
I don't have a link right now, but I remember that it was an exam question
jherlihy1
Hmmm.. just found this on FieldPortal which says NO to all the above: https://fieldportal.netapp.com/ci_getfile.asp?method=1&uid=6347&docid=32820
gautamj
Please open a PVR with customer name and provide all details. I have received 4 PVRs so far. I believe there are more opportunities out there but not hearing them so I encourage folks to open a PVR. We are working on putting together a plan to formally qualify SMxin XenServer environment
lederman
Anything new on this?  I'm hearing from customers who would like to run SME in Xen-hosted VMs, but I don't believe NetApp supports that yet.  You can map to "raw" NetApp LUNs using Storage Link in Xen, but the SD/SME support just isn't there yet, correct?
