Cloud Volumes ONTAP
CVO for AWS Single node Create problem
chappychappy
I occured CVO for AWS Single node Create problem.
It seems that Possible conflict with IP addresses in the 172 range issue.(172.17.0.0/16 and 172.18.0.0/16)
  Refer to docs.netapp.com/us-en/occm/reference_issues
Is there a procedure to change the Docker Bridge IP address(172.17.0.1/16) in the connector somewhere?
Regards,
1 ACCEPTED SOLUTION
jsuarezs
Hello @chappychappy !
Indeed there's a way to change it by NetApp support team. I recommend you to open a support ticket to apply this internal procedure.
Regards,
Javi.
Nothing is simple so be simpler.
2 REPLIES 2
jsuarezs
Regards,
Javi.
chappychappy
Hello Javi-san,
Thank you for your reply.
I escalated to the NetApp support team and was able to successfully build a CVO.
Thank you very much.
Regards,
