Community Related Discussions
AFF A70/A90 chassis replacement
lalala
Could you explain why the chassis HA configuration is no longer required after a chassis replacement? I noticed that in the latest version of the replacement procedure manual, this step is no longer included.
2 REPLIES 2
Amador
In this NetApp platform, as in others (HA interconnect procedure guide for ASA, AFF and FAS platforms - NetApp Knowledge Base) the HA interconnect is established through external cabling and not the internal chassis connection, as in previous systems.
More information at Cable the hardware - AFF A70 and AFF A90
lalala
The following procedure is no longer included in the latest version.
Set the HA state for the chassis:
ha-config modify chassis HA-state
