Data Protection
After update to Snapcenter 4.5 Problem with Exchange Up to the minute retention log delete
GREGD
We update Snapcenter from 4.3.2 to 4.5P2
I have a DAG Exchange with two server and 6 DB.
After upgrde to 4.5P2 i get warrning  there are more logs which cannot be deleted. And i have it delete manually on the server.
The backup job 369165 has completed on primary.
Status: Warning
Error:
Failed on 'EXCSRV01':
Activity 'Up To The Minute Retention' failed with error: Failed to delete one or more log backups.Go to the respective log folder in 'E:\SceBackupInfo\EXCSRV01\DB1\RG_EXCHANGE2016_excsrv01_02-11-2022_22.45.03.6225,..........
Backed up objects:
Exchange Database - DB1
Exchange Database - DB2
Exchange Database - DB3
Exchange Database - DB4
Exchange Database - DB5
Exchange Database - DB6
Attached is the backup details report for Resource Group [RG_EXCHANGE2016] Policy [BP_Exchange_Full]
thanxs for help
1 ACCEPTED SOLUTION
GREGD
After 2 weeks i find the solution.
In my situation the Policy retention was not working correctly.
I get warning that some folder on exchange could not be removed.
But my retention is 7 Days so snapcenter should not delete the log every day.
Normaly i used chrome or firefox to connect to snapcenter console.
Solution for me:  i login to snapcenter console direct on Server and redeploy the resource group and also the settings . by both i wait 5 second betwenn next click on next button. So after that policy is working corectly i have 7 day up to minute logs and also delete is happend without warning.
3 REPLIES 3
GREGD
It looks that netapp cannot delete last log fie before full is started.
GREGD
GREGD
EDIT
I get the error again , and now when i change that i make only FULL not as before FULL and LOG everything is working correctly.
