Data Infrastructure Insights
Cloud Insight AWS EC2 EBS monitoring for region ap-east-1
ACW-CalvinWong
hi all,
I would like to monitor ec2 and ebs which are located in ap-east-1, but can't find this option, anyway to monitor this region's resources via cloud insight?
1 ACCEPTED SOLUTION
ostiguy
Hey Calvin,
I thought this was fixed, but we are also intending to get rid of this entirely because this collector is now multi-region - it should automagically discover everything across all regions.
In the short term, I would try using us-east-1 as a value, but so long as your credentials are valid, I believe we should discover all the accounts your account has access to, and all the EC2/EBS resources in them across all geographies.
If you want to send me a Private Message with your CI tenant URL, I can look a bit deeper
Thanks,
Matt
4 REPLIES 4
ostiguy
Hey Calvin,
Thanks,
Matt
ACW-CalvinWong
just test it works by randomly select any region, much thanks~
ACW-CalvinWong
Hi Matt, thx for quick reply! I am also trying on the azure connector, thx!
let me try again with us-east-1, should have any further issues will further let you know!
Thanks,
Calvin
ostiguy
Hey Calvin,
Azure's APIs are region neutral, whereas Amazon has a lot of $service.$region.someamazon.domain.here API endpoint hostnames. This won't be a problem with our Azure, or Azure NetApp Files collectors
Matt
