Data Protection
Adding storage systems and hosts in snapcenter
Zagwa
I have installed Snapcenter in my environment and I am having issues adding storage systems and host the errors I am facing are as attached. The chose storage type area is grayed out. Please let me know if one has a solution to this issue
1 ACCEPTED SOLUTION
mrahul
Hi Zagwa,
     With SnapCenter you can register/add ONLY SVMs.
What you see is expected behavior, as designed. Support for registering/adding cluster is coming in the upcoming release.
3 REPLIES 3
mcjunkin
You have to connect to the SVM, not the cluster.
Zagwa
The thing is, where I need to select sorage type is sort of grayed out, I can't make a selection and ONTAP SVM sort comes in as default as is locked there
mrahul
Hi Zagwa,
