Data Protection
Backup problem about after fix the Apache Log4j Vulnerability for snapcenter
Terry_Lui
20th of DEC, I just follow the step provided from NetApp support to fix the vulnerability for apache Log4j in snapcenter.
After few days, I just want to check snapcenter status, I find it the backup jobs was stop after 20DEC 1PM. There was two resource groups was find out the same problem. Any idea or recommendation about this backup fail after fixed the log4j vulnerability? Many thanks.
Resource  Groups:
Screenshot 2021-12-31 015737.pngScreenshot 2021-12-31 015822.png\
Result for fixed for log4j:
1 ACCEPTED SOLUTION
aladd
Is it only scheduled jobs that are impacted here?
2 REPLIES 2
aladd
Terry_Lui
yes there, but we being normal after upgrade to 4.4.1. thanks again Aladd=)
