Data Protection
Can Load Sharring Mirror use in data volume
AllenChang
I try to create a load sharring mirror,
and apply it to a data volume,
the message appear
Error: command failed: Source volume "lsv_source" for load-sharing SnapMirror relationship is a data volume and not a Vserver root. Support of load-sharing relationships on data volumes is deprecated. If you want to use load-sharing relationships on data volumes, contact technical support.
So,If any chance to use load sharring mirror in data voume ?
1 ACCEPTED SOLUTION
Sergey_Osipov
to use LS-mirror in data volume you would need to open a case with technical support and get FPVR request approved
3 REPLIES 3
Sergey_Osipov
AllenChang
Hi Sergey
Thanks your answer
What type of case will be deliver?
Remote help ? or a License Key ?
Sergey_Osipov
Technical request to enable load-sharing for the data volume
