Data Protection
Enabling and configuring MPIO for existing iSCSI connection
Tomislav
Hello!
I have a customer who has Exchange 2013 (Windows Server 2012) on Hyper-V virtual machine and for backups is using Snapmanager for Exchange 7.0.0. Except Snapmanager for Exchange on virtual machine is also installed Snapdrive 6.5. Exchange LUN's are on FAS2240-4 and VM is using iSCSI protocol for connecting to those LUN's. For now there is one iSCSI network adapter in VM and I would like to configure a second one and configure MPIO. On Hyper-V host it will be configured second virtual switch for iSCSI connections for that second iSCSI network adapter of virtual machine.
What would be or procedure for installing and enabling MPIO in OS on such existing production environment?
Any help would be much appreciated!
Regards,
Tomislav
4 REPLIES 4
HONIG2012
i suggest:
0. create a snapshot of vm (just in case...)
1. install Netapp-Host-Utilities (if not already)
2. enable MPIO within Windows Features
3. enable MPIO support for ISCSI-devices
4. install Netapp-DSM (the MPIO stuff if you want to use it from netapp)
5. reboot system
6. add second NIC to VM and configure it
7. configure ISCSI within VM to use also the 2nd NIC
that's it.. good luck!
-AJ
Tomislav
@HONIG2012 wrote:
i suggest:
5. reboot system
-AJ
Thanks for your answer!
Few more questions from me. Is it nessery to install NetApp Host Utilities if now they are not installed but existing single iSCSi connection is working as expected? If I understend correctly I don't need NetApp DSM and I can use native microsoft DSM?
HONIG2012
DSM is optional if you're about to use microsoft MPIO but Host Utilities are mandatory - they set timeout values within your OS. these timeouts gives your machine the ability to survive a controller takeover or short network outages
you can install them without losing your existing connections but a reboot is required.
Tomislav
