Data Protection
Flexclone with snap drive for unix
crondeau1
Good day,
I have a customer that is looking at flexclones for his oracle environment.  He is using snap drive for unix on a Redhat box.  Are the flexcloes still initiated from the filer then connected using snapdrive or are they initiated from the host?
Thanks
Clayton
3 REPLIES 3
rgeoff
according to the admin guide for snapdrive for unix the following actions are supported: http://now.netapp.com/NOW/knowledge/docs/snapdrive/relunix40/pdfs/install_linux.pdf
SnapDrive for UNIX operations on FlexClone volumes
There are various operations which you can carry out using on FlexClone volumes using SnapDrive
for UNIX. This section provides example of few SnapDrive for UNIX operations on the FlexClone.
Next topics
Role based access check for FlexClone operations
on page 132
Snap connect procedure
on page 133
Snap disconnect procedure
on page 133
Connecting to a single
filespec in a LUN
filespec in a LUN
on page 134
Connecting to multiple
filespec
filespec
on page 135
Disconnecting a
filespec
filespec
on page 137
Splitting the FlexClone
on page 138
Space reservation with FlexClone
on page 138
Snapdrive for unix does not create a flexclone, that would have to be done via script, then use the procedures above to connect to the lun...
Thank you,
crondeau1
Thanks.  That is what i thought.
Cheers
rgeoff
After reading through the details of the link that I sent you, I was incorrect with my above statement Snapdrive for Unix can initiate the flexclones. look at this link: http://now.netapp.com/NOW/knowledge/docs/snapdrive/relunix41/html/software/install_linux/cloning/concept/c_sd_clon_snap-connect-proc.html#c_sd_clon_sn...
Specifically see bold:
  1. Snap Drive for UNIX chooses an appropriate cloning method for storage system entities based on CLI configuration options as given below:
  2. If -clone lunclone option is specified in the CLI or the san-clone-method=lunclone option in the snapdrive.conf file, then SnapDrive for UNIX creates a LUN clone in the same volume from the given snapshot.
  3. If -clone unrestricted option is specified in the CLI or the san-clone-method=unrestricted option in the snapdrive.conf file, then SnapDrive for UNIX creates or reuses all-purpose FlexClone from the given Snapshot.
  4. If -clone optimal option is specified in the CLI or the san-clone-method=optimal loption in the snapdrive.conf file, then SnapDrive for UNIX automatically chooses between restricted FlexClone and LUN clone, based on storage system configuration.
