Data Protection
Help with SnapManager server is busy issue.
praneeth_vegunta
I have a SnapManager running on version 5.0. We have a clustered windows server and configured Snapmanager backups for sql server.
everything was working fine untill a week ago where we keep seeing messages as below.
[18:01:27.664]  Get all destination volumes state successfully.
[18:01:27.664]  SnapManager server is busy, please wait...
[18:01:37.664]  Re-trying...
[18:01:37.664]  Error Code: 0xc0040817  There is another SnapManager operation currently in progress on this server. Please retry this operation after the conclusion of current job.
any Help is much appreciated.
Thanks,
Praneeth.
1 ACCEPTED SOLUTION
olson
.Hello,
     Start with the service. Restart Snapmanager for X service. You should then look for overlaping jobs or long running jobs to ensure they are schedule spaced out correctly.
Regards,
John
3 REPLIES 3
olson
.Hello,
Regards,
John
dalemarshall
I've got this same issue.
I can't see any overlapping jobs. If I look in SQL studi Manager I can see that all the jobs are idle.
As soon as I restart the SnapManager service it's find but then a couple of days later I'll get the same issue.
praneeth_vegunta
I would suggest deleting any jobs relating to SNAP manager for sql server, restart the sql services and then recreate them.
Thanks,
Praneeth.
