Data Protection
Help with Snapmirror error: Failed to create Snapshot (Invalid Argument)
frank_iro
Hi,
Having trouble with a snapmirror update not completing. It fails with the following error:
Failed to create Snapshot copy on volume [svm]:[volume] (Failed to create Snapshot copy on volume b079364c-3655-11e7-b5b9-00a09897da7d:[volume] (Invalid argument)
Can't seem to find any info as to what that means, and why it's happening.
Replication is happening between to different countries via VPN. I have about 7 volumes replicating. This is the only one that fails.
Any pointers?
Thanks.
1 ACCEPTED SOLUTION
frank_iro
Hi,
So I managed to resolve this, but realized I hadn't updated the forum post. Just needed to throttle the failing snapmirror relationship a little and it stopped failing. So, issue resolved.
Thanks for the response though.
Cheers.
2 REPLIES 2
Ontapforrum
Hi,
Could you check if there is enough space on the destination aggregate?
Please give us some more info to help you with.
Source Cluster version
Dest Cluster version
::>snapmirror show -fields  last-transfer-error  -destination-path SVM:/path/that/is/failing
::>event log show
Thanks!
frank_iro
Hi,
Cheers.
