Data Protection
Issues with 6.1 Installation
LIVEEVIL82
Hi All. I have searched and cant seem to find anything to point me in the proper direction on this one. I have done a 6.1 installation previously without issue so again, not sure why this time.
6.1 installation on a SharePoint 2013 farm (that part is new to me).
1 App, 1 WFE, 1 SQL server.
Agents are installed and security is set to propers according to documentation.
Here is the issue, the agents all say they are non-Sharepoint agents (in the Agent Monitor/Farm Info). Thusly Im not getting any farm information to finish confguration r setup a backup.
Any clue as to where I went wrong or where to go from here?
Thanks!
Jason
1 ACCEPTED SOLUTION
vanhees
Hi Jason,
For SharePoint 2013 you need SMSP 7.1.1.
Cheers,
Hans
2 REPLIES 2
vanhees
Hi Jason,
Cheers,
Hans
LIVEEVIL82
That would do it! Thanks, Hans.
