Data Protection
Monitoring
benpielaml
What are people using out there for monitoring their NetApp controllers?  Is it a combination of Ops Manager and SNMP?  What traps do you typically monitor?  Are you creating your own custom traps?
Thanks,
Ben Piela
8 REPLIES 8
stevedegroat
Using DFM/Ops Mgr as the primary method for monitoring and problem notification.  I do have a modified SNMP script for collection in Big Brother (not officially supported by NetApp).  We will soon be moving to Nagios, which is supposed to have better interpretation of NetApp mibs.  For example we had to turn off Big Bro's monitoring of environmental data points as it continued to report temperature issues where there were none.
michaelhudak
Hello Ben,
I have started a posting in my Linkedin to give you different ideas, you can follow the thread to the right http://www.linkedin.com/groupAnswers?viewQuestionAndAnswers=&discussionID=27817909&gid=116876&commentID=21528437&trk=view_disc
Feel free to conect with me as well my email for Linkedin is [email protected]       http://www.linkedin.com/in/michaelhudak36
Kind Regards,
[email protected]
Michael Hudak
NetApp Sales Specialist
Virtualize Everything.
netapp.com/guarantee
storage calculator
Champion Solutions Group
Don't buy servers. Create them!
791 Park of Commerce Blvd - Ste 200
Boca Raton, Florida, 33487
dir 561-997-2900 X 344
fax 561-997-4043
Message was edited by: Michael Hudak
michaelhudak
Some folks prefer ApplianceWatch PRO w/ Microsoft System Center while others choose HP OpenView, ManageEngine OpStor, LogicMonitor, Nagios, etc.
See here:  http://communities.netapp.com/message/30854
S_EFTEKHARI
Another way you can monitor NetApp is using SCOM / OpsMgr management pack, or solarwind NetApp Profiler. I have used the older version of Profiler in the past and it worked very well. Those are some of the things you can consider and of course budget is important factor. SCOM requires a lot of planning and it makes Changes to AD. I think SolarWind its better option if you already own the product.
http://www.vnext.be/2011/01/08/scom-opsmgr-netapp-management-pack/
http://www.solarwinds.com/resources/datasheets/solarwinds_storage_profiler_for_netapp_datasheet.pdf
watan
Also just fyi,   the vnext link notes ApplianceWatch PRO 2.1 which was a previous release.  The latest release is now called NetApp OnCommand Plug-in for Microsoft 3.0 ->  http://media.netapp.com/documents/ds-3090.pdf
DBTUNA_JACKY
Check out www.dbtuna.com.  It's monitoring software that works with NetApp at the controller level.
BISHTECHIT
we use a combo of Solarwinds     &. NetApp DFM - DFM polls the NAS traps which get reported to Solarwinds.
LADYJESSICA
Hi Ben,
You could also use Splunk. We have recently release our free Splunk App for NetApp Data ONTAP.
http://www.splunk.com/view/netapp/SP-CAAAJGQ
More info here
http://apps.splunk.com/app/1293/
Regards,
Stela Udovicic
Splunk
