Data Protection
NDMp backups are fail as maximum number of dumps/restores allowed is reached for a filer.
Deepak1254
Hi All,
We are using Veritas Netbackup to take NDMP backup on a netapp filer. The backups were working fine since last few days. Recently, backups are started to fail with below error.
NDMP_LOG_ERROR 1 DUMP: Maximum number of allowed dumps/restores (4) in progress
We have a setup where 6 jobs for same filer will be running together. Because of this issue we had to change limit to 4 to avoid failures. However, this is impacting on time to complete backups. Is there anyway we can change limit for a filer?
Thanks,
Deepak
2 REPLIES 2
Sahana
Hi,
Please refer KB https://kb.netapp.com/support/s/article/how-do-ndmp-session-limitations-work-with-data-ontap-8-2-and-later?language=en_US
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Deepak1254
HI Sahana,
Thanks for the KB article. We are checking on the same. I will get back to you if we can able to overcome the issue by implementing this.
Regards,
Deepak R
