Data Protection
Need help in configuring snapdrive 5.0 on linux
RAVIKANTHB
Hi All...
I am basically a unix admin and complete newb to snapdrive. i have installed installed snapdrive rpm 5.0 on our linux host to backup our filesystems.....alll i have done is intalled the rpm and confirmed the daemon is running and after that tried running the command to test backup of fs but it failed with below error,
snapdrive  snap create -fs /u01/app/oracle/product/wcp -snapname testsnap
0002-106 Command error: Failed to resolve filespec information
Not sure if there is anything else i need to configure, Also if the command was successfull how do i know where does the snapfile gets created.
Regards,
Ravikanth
1 REPLY 1
klemen_bregar
Hi!
A little bit late , but.....did you solve this problem?
We are getting the same erorr
With regards,
Klemen
