Data Protection
NetApp Power Shell Tool Kit
Suhaib_Ali
Dear Community support.
we are using ONTAP PowerShell ToolKit to automate the SnapMirror failover failback procedure. We are unable to find the reverse sync script for failback.
The source SVM is SVM1 and the destination SVM is DR_SVM1.
volume on source is App_Repo_32k and destination App_Repo_32k_des
Also kindly provide the correct failover and failback procedure with PowerShell ToolKit.
Thanks
0 REPLIES 0
