Data Protection
Problem pushing out SnapCenter
GingerBeardGeek
I had an issue with backups suddenly failing stating that a job was already running, even though it had cancelled.
I removed the plugins and the Host and then tried to redeploy, but it keeps failing. The error in the install log is:
9-21-2020[01:02:13 PM]: (CLR Action): SWInstallerHelper: Begin CheckStaleServiceExist.
9-21-2020[01:02:13 PM]: Engine: property 'IS_STALE_SERVICE_EXIST' value now 'true'
9-21-2020[01:02:13 PM]: (CLR Action): SWInstallerHelper: CheckStaleServiceExist: SCWPluginService is exist, remove the service manually & re-try the installtion again
9-21-2020[01:02:13 PM]: Action returned value 0x00000643
9-21-2020[01:02:13 PM]: Action 'CheckStaleServiceExist' returned status 0x80070643
9-21-2020[01:02:13 PM]: Original exit status: 0x80070643, final exit status: 0x00000643
I have checked the registry for any stale NetApp registry keys and cannot find any. I have checked the "Program Files" folder and there is nothing there. Where else could the installer be looking when performing this 'CheckStaleServiceExist' routine?
1 ACCEPTED SOLUTION
hmoubara
Hello,
Have you tried rebooting the server and re-try the operation? if not please perform a reboot and try again.
If reboot was already performed, please follow the kb below on how to remove stale entry for snapcenter plugin:
https://kb.netapp.com/Advice_and_Troubleshooting/Data_Protection_and_Security/SnapCenter/Manual_remove_SnapCenter_Plug-Ins_from_Plug-In_host
Thanks
3 REPLIES 3
hmoubara
Hello,
Thanks
GingerBeardGeek
Thanks for the response and the link. The SnapCenter server was rebooted at the weekend for patching. The host server which I am trying to add is due for a reboot next Monday, as it is a clinical system, and we must plan downtime. I have checked and it is in a pending reboot state at the moment. Hopefully, this is what is causing the failed installs.
GingerBeardGeek
All sorted now. Thanks again.
"sc delete SCWPluginService" was the command which cleaned up the last bit of the plugin.
