Data Protection
Problem with SnapCenter clones
MARK_SAUNDERS
Hi all,
I have just setup snap center to backup some NFS volumes attached to a Linux server and the backups are all fine but when I try to run a clone to mount a backup I am getting the issue where SC picks the wrong interface from the SVM so the host does not have access.
I have found the fix for this for a Windows host or an ESX server is to put an entry in the SMCoreServiceHost.exe.Config is there a similar config file for a Linux host or am I only to create clones and mount them manually ?
0 REPLIES 0
