Data Protection
Problem with Snapmanager 5.0 for Sharepoint
pascal_grout
Hello,
We have a problem with Snapmanager for Sharepoint.
This is the alerts log:
338067 MB data, 0(0) site collections, 0(0) sites, 0(0) lists, 0(0) items. Error During Backup Raw DB: Export-config command execute failed!Pipeline State Changed to Failed: Failed to invoke the configuration export operation. Error During Backup Raw DB: Export-config command execute failed!Pipeline State Changed to Failed: Failed to invoke the configuration export operation. Error During Backup Raw DB: Export-config command execute failed!Pipeline State Changed to Failed: Failed to invoke the configuration export operation. Error During Backup Raw DB: Export-config command execute failed!Pipeline State Changed to Failed: Failed to invoke the configuration export operation.
This is the error log:
Command line:
export-config -ControlFilePath "C:\Program Files\NetApp\SnapManager for SharePoint Server\VaultClient\045a114a-4424-4b1a-8727-81073952831a.xml" -Server "SQLCLUSTER-A2\SQL_A2" -Section "storage","snapmirrorvolume" -verbose:$True
ErrorMessage:
PSObjectOutput:
[09:26:05.1623947]: Initializing [export-config][System.String]
[09:26:05.2073992]: Connecting to server: [SQLCLUSTER-A2\SQL_A2][System.String]
[09:26:07.3816166]: The input parameters are being validated.[System.String]
[09:26:07.3836168]: The sections [storage snapmirrorvolume ] will be exported from Server: SQLCLUSTER-A2\SQL_A2.
[System.Collections.Generic.List`1[System.String]]
[09:26:07.3836168]: The input parameters validation successful.[System.String]
[09:26:07.3846169]: Proceeding with [export-config][System.String]
[09:26:07.3906175]: Getting all the client side settings for export on [SQLCLUSTER-A2\SQL_A2][System.String]
[09:26:07.3916176]: [SQLCLUSTER-A2\SQL_A2] is cluster instance.[System.String]
[09:26:07.3916176]: Active node name: SQL02-D[System.String]
[09:26:07.3966181]: Export the settings ...[System.String]
[09:26:33.4972279]: Fail to export current configuration of server [SQLCLUSTER-A2\SQL_A2]. Please check Windows event log for detailed information.[System.String]
[09:26:33.5072289]: Failed.
Maybe that someone can help me about tthis eror?
Thanks,
Pascal
5 REPLIES 5
vrishali
I'm on leave from 30th Oct to 12th Nov. Please contact my manager
Senthil (senthilk@netapp.com) for anything urgent.
Thanks,
Vrishali
soumende
Were you able to get the answer for your problem. If not please please let me know.
craigtw
Did you get this problem resolved?  I am now experiencing the same problem, and any information you can provide would be helpful.
pascal_grout
The indexing server is a VM with two raw lun, and these raw luns are logs fors searching, you can't backup these with snapmanager.
It is posible but you must connect the lun's with snapdrive as normal lun's. (backup/copy al to the new lun)
It happens when i try to make a (full) backup of everething.
Pascal
MOHITDAS123
Hello All,
Our Scheduled Jobs keeps failing and says Completed with Exceptions.
Did anybody get a resolution for the above issue, our Backups are failing since December , it sometimes runs on Weeknds and we tried all ways to get this running but it still doesnt work, can any body suggest any solution.Thanks in Advance
