Data Protection
Relation between VSS and Snap manager for SQL
vijayasekars
Does Netapp uses Microsoft Volume Shadow Copy Service for backing up sql database using Snap manager
1 REPLY 1
BrendonHiggins
Welcome to the community.
It depends on what versions you are running but VDI is part of VSS.
http://msdn.microsoft.com/en-us/library/ms175536.aspx
Loads more here
http://msdn.microsoft.com/en-us/library/cc966520.aspx
Hope it helps.
Bren
