Data Protection
SDU 4.1.1 help
bethel
IHAC who is running 64 bit RHAS 4 u6 with 32 bit emulation installed.  I have a problem that looks like the typical HTTPS/SSL being the default setting of snapdrive.conf.  HTTPS/SSL is turned on on the filer.  "snapdrive snap list -filer filername" works.  "snapdrive config access list filername" shows:
        Commands allowed:
                snap create
                snap restore
                snap delete
                snap rename
                storage create
                storage resize
                snap connect
                storage connect
                storage delete
                snap disconnect
                                                storage disconnect
When I do a "snapdrive storage show -all", I receive:
0001-185 Command error: storage show failed: no NETAPP devices to show or add the host to the trusted hosts (options trusted.hosts) and enable SSL on the storage system or retry after changing snapdrive.conf to use http for storage system communication and restarting snapdrive daemon.
I'm confused.  Why would the first 2 commands succeed and the last one fail.
Thanks
2 REPLIES 2
pascalduk
The error message says either you don't have LUNs connected or snapdrive can't access the filer. Since you already verified that access works, the error appears because you don't have LUNs connected.
Did you already try connecting or creating a LUN?
adityav
Have you connected luns to the host ? If you have , then send the trace logs by running snapdrive.dc utility
