Data Protection
SM4SQL: possible to combine with SQL-Backup?
mhasenbeck
Hello Community,
we are using an SQL 2008 x64 Standard with SMSQL (5.0 R1) - my question is, if
there is an known problem in using the SMSQL for example from 6 to 22 and the
SQL-Standard-Backup from 23 to 5 o´clock? Exactly at this time i want to verify
some of the 16 Snapshots which the SMSQL did before...
At the first time the SQL-Recovery-Mode will be set to "simple", so there is no
seperate backup of the T-LOG needed.
Thank you for some information and your opinion
Marc
1 REPLY 1
jeffbennett
Marc,
Can you elaborate on the known problem with SMSQL between 0600 and 2200?
Thanks
Jeff
