Data Protection
Data Protection
Hi all,
I got a queston from a customer if SnapManager for Oracle is supported on an Oracle VM virtual machine. I looked through Interoperability matrix, as well as NOW and FieldPortal, but could not find concrete information.
VMWare and Hyper-V are mentioned in SMO install&admin guide, so I presume Oracle VM is possible too. What I would like to have is a more concrete info with limitations/possibilities.
Is there anyone with experience in implementing SMO on Oracle VM virtual machines? What disk configuration did you use (RDM, iSCSI, NFS)?
Thanks in advance,
Mladen
Mladen,
Currently only iSCSI and NFS are supported in Linux. In windows, iSCSI and RDM's are supported.
These dependencies are based on what SnapDrive for UNIX/Windows supports.
Regards,
Craig
No it is not. The IMT does contain the references you are looking for. Select your SMO configuration details based on the customer config and then check the applicable IMT Notes for the row that best matches your config. You should see references to the supported virtualization environments.
A PVR may be an option. The account team would need to make the necessary Product Management contacts in order to proceed on that approach.
-Mark
Hi,
actually I have the same question than jessick and the IMT notes are not so clear.
For instance, I need to know if I can use SMO on VMWare ESX4 with vfms and/or RDM.
For VMWare, the SMO notes says:
SnapManager for Oracle (SMO) on Windows is supported on Guest OS only for VMware ESX 3.5 Update2 for both iSCSI and FibreChannel. VMware ESX 3.5 Update 2 and later or ESXi 3.5 Update 2 and later is required to support Windows 2003/2008 Guest OS (x86, x64) using RDM LUNs via FCP HBA or iSCSI SW initiator from within the Guest OS. SMO on Windows is supported on Guest OS only for MicroSoft Virtual Server2005R2 (SP1) for ISCSI protocol. See the SnapDrive for Windows Support Matrix for additional support details.
Does it means that Oracle on VMWare is not support with ESX 4 ?
Does it mean that it works only with RDMs ? Or can it work with VMFS as well ?
Thank you for any help ....
Regis
I'm on leave from 30th Oct to 12th Nov. Please contact my manager
Senthil ([email protected]) for anything urgent.
Thanks,
Vrishali
Hi Regis,
I would like to understand your requirement clearly first. Are you seeking SMO' s support on underlying SDU (Unix) or SDW (Windows)?
If it is Windows, then here are your answers:
1. Does it means that Oracle on VMWare is not support with ESX 4 ?
For Windows, I have already replied. For Unix, it works only with RDM's and not with VMFS.
Hope this helps.
Thanks,
Piyush
SMO/SMSAP QA Lead
Thanks,
Vrishali
Thanks,
Vrishali
Answers to your questions:
{Piyush} Yes.
{Piyush} Since, the support is NOT there on Windows yet, there is no question of whether RDM or VMFS.
Hope it is answered now.
Thanks,
Piyush
Thanks,
Vrishali
Thank you Piyush.
Is it a matter of time? If so, do you know of an ETA ?
Would a PVR help ?
Regards,
Regis
Thanks,
Vrishali
Hi,
are there any news about support of SMO in Windows guest OS with VMWare 4.x. Notes still show only VMWARE 3.5 (min. Update 2) as the only supported configuration.
Thanks.
AB
HI Piyush,
has the situation changed since last november ?
The SMO 3.1 matrix still doesn't show ESX 4.0 (note 1281).
But the Snapdrive for Windows 6.3 matrix shows support for ESX 4.0 ?
Thank you
Regis
