Data Protection
SMSQL build (2.1.1.689) x86 issue
ivissupport
Hi all,
There is an error when try to connect from the remote SMSQL to the production SQL Server.
The error is:
You are connecting to an an earlier version Snapmanager Server
Please upgrade your Snapmanager for SQL Server on 'computername'
If anyone can help i will appreciate it
Thanks in advance
Aggelos
1 REPLY 1
sourav
Hi Aggelos,
I can recall this error faintly. It appears in some SnapManager cases and does have a fix. I would advise you to contact NetApp support and get the fix.
Regards,
Sourav.
