Data Protection
SMSQL - how to migrate system and temp DB of a clustered instance?
radek_kubka
Hi,
I'm running SMSQL (v6.0.0) config wizard against a clustered SQL instance & it seems to ignore system and temporary databases of this instance.
It shows correctly these databases for the default (non-clustered) instances from both nodes & I have the option to migrate them to NetApp LUNs - but not for the clustered instance.
Is that intentional? Or am I missing something?
Thanks,
Radek
0 REPLIES 0
