Data Protection
SRM with Mirror and Vault
chris_hague
Is SRM supported with an Mirror & Vault relationship? (XDP) or does it only work with DP ?
Anyone using this?
2 REPLIES 2
RPHELANIN
Pretty sure snapvault is still not supported
chris_hague
Thanks
How about if using a cascade?
e.g. SRM uses a DP relationship, but then also use that destination volume as the source for an XDP "vault" ?
Trying to avoid having to send all data between sites twice.
