Data Protection
SnapDrive for Unix error when creating RDM lun (0001-476 Admin error)
raskovicm
Hi,
I am using SDU v4.2 on RHEL 5.6 guest os to create RDM lun and keep getting this error:
[root@test01 /]# snapdrive storage create -lun fas3140a.domain.local:/vol/test01/lun01 -lunsize 1g
        LUN fas3140a.mprh.local:/vol/test01/lun01 ... created
        exporting new lun(s) to Guest OS ... done
        discovering new lun(s) ... *failed*
        Cleaning up ...
        deporting lun(s) from Guest OS ... done
         - LUN fas3140a.mprh.local:/vol/test01/lun01 ... deleted
0001-476 Admin error: Unable to discover the device associated with fas3140a.domain.local:/vol/test01/lun01.  If multipathing in use, there may be a possible multipathing configuration error.
Please verify the configuration and then retry.
Documentation states that MPIO is not supported in this config (since I am using vmware guest OS).
I have set transport protocol to fcp in snapdrive.conf and added virtual center with snapdrive conf set -viadm....
sdconfig check looks like this:
[root@test01 bin]# ./sdconfcheck check
Detected Intel/AMD x64 Architecture
Detected Linux OS
The SDU Configuration Checker could not detect any of the transport
protocols supported by SnapDrive.
Detected   Ext3 File System
Did not find any supported Volume managers.
Detected   Linux Native MPIO
Did not find any supported cluster solutions.
Did not find any supported HU tool kits.
sdconfcheck: ../../../messageinfo/src/messages.cpp:145: void messageinfo::messageParse::parseRecord(std::string&, std::string&): Assertion `false' failed.
Aborted
Anyone with idea or suggestion?
Update - storage is in my /etc/hosts file, root user is used to access storage so RBAC would not be the problem
1 ACCEPTED SOLUTION
arunchak
HI,
   See attached the error and possible cause as extracted from SDU guide.
  I guess you have installed and configured Host utilities?
Thanks,
  Arun
5 REPLIES 5
arunchak
HI,
Thanks,
  Arun
raskovicm
Hi, I saw that in SDU manual.
The problem was in order of prerequisites installation. I installed linux host utilities after snapdrive, and snapdrive was not aware of them. I did not install them before SD because SDU documentation states (page 27) that host utilities are required only if protocol is iSCSI.
Thx!
arunchak
Welcome
Actually your sdconfcheck also showed
"Did not find any supported HU tool kits"
Also, this a generic error.
If the order of installation was the issue, did you try restarting the snapdrive service and find if that detected HU?
Thanks,
  Arun
raskovicm
Yes, tried to restart snapdrive daemon, and whole server too, but did not help. I had to uninstall SDU and install again.
arunchak
Interesting.... Anyways thanks for the response
Thanks,
  Arun
