Data Protection
SnapManager Sharepoint - How to restore a single Project?
Marius_H
Hi,
we've Sharepoint / PWA 2013 running on our site and are using SnapManager Sharepoint for backup.
How can I restore a single project out of the "Project Center" list?
On the restore Screen I go to "Microsoft Sharepoint Foundation-WebApplication"\<our site>\WSS_Content -> View granular content.
If i navigate further to PWA\Sites I can see the project websites under "Sites". But the test project I wanted to restore doesn't have a website configured.
Thank you very much for any hints.
Marius
1 REPLY 1
Jeff_Yao
https://library.netapp.com/ecm/ecm_get_file/ECMP1155474
page 42
  • Granular Restore Level If granular indexing options were selected during backup, individual site collections, sites, libraries, lists, folders, items, or file/item versions can be restored from the content databases after clicking the View Details link on the top-right corner of the Backup Data pane. You can also search for the content to be restored by clicking Advanced Search on the ribbon and search using the entered criteria.
hopfully helps
