Data Protection
SnapMgr for SQL for Move Data Base?
henrypan1
Dear NetApp Gurus,
May I use SnapManager for SQL version 6 to move MS SQL Data Base between hosts?
Thanks in advance & looking forward to hear from you
Henry
1 REPLY 1
soumende
Henry the latest version of Snapmanager for SQL is SMSQL 5.1. It is unclear from the question if you would want to move the database between the windows host or are you referring to the storage controllers.
If you would want to move the databases between hosts then you cannot use SMSQL.
