Data Protection
Solaris LDOMs running SMO
tabascoblues
Does anyone have any clue whether we can run SMO on a solaris LDOMs?  The problems seems to be that the hypervisor masks the LUNs to the logical hosts as virtual drives.  From the solaris side, is there a way to do a direct mapping of the luns?  From the Netapp side, can I use NFS or Oracle DNFS to bypass this issue?
1 REPLY 1
Jeff_Yao
ldom can create virtual hba and assign to guest os. so theoratically it should work.
https://blogs.oracle.com/jsavit/entry/virtual_hba_in_oracle_vm
