Data Protection
What is the difference between SQLINFO and SQLSNAP
alliantenergynjk
We use SnapManager for SharePoint, which requires and uses SMSQL.  On our VMware datastore, I see snapshots with SQLINFO in the name and SQLSNAP in the name.  The SQLINFO appears just on the volume used for C: drives while the SQLSNAP appears on the volume used for the SQL databases.  Does anyone know what the difference is between these two?
Thanks
NK
1 ACCEPTED SOLUTION
alliantenergynjk
I think I see.  Our SnapInfo drive (I drive) shares the same datastore as the C: drive.  It looks like some sort of snapshot is happening automatically of the SnapInfo directory drive (I).  Probably just the way the product works by default.
NK
2 REPLIES 2
alliantenergynjk
NK
dmauro
indeed. SMSQL works by design in creating two snapshots of the volume hosting the log/Snapinfo LUN, for each backup set. you will see a slightly different result when logs and snapinfo not being on same volume (which will then create 3 snaphots instead of 2), but it is still working as designed.
Domenico.
